Discussion topic: Lenovo laptop will not connect to sky max wifi
Message posted on 25 Nov 2024 08:52 PM
Any one else having problems connecting their laptop to sky max hub does not recognise sky wifi
Message posted on 25 Nov 2024 10:33 PM
Re: Lenovo laptop will not connect to sky max wifi
May be because it on wpa3 change it to wpa2 in the sky app and try that
Message posted on 26 Nov 2024 06:32 AM
I have still doesn't work
Message posted on 26 Nov 2024 06:48 AM
@Mandy601 what model laptop are you trying to connectvand what operating system is it running?
Message posted on 26 Nov 2024 11:31 AM
My Laptop is Lenovo G50, won't connect to the Sky Max Hub which was installed in October, Sky are being unhelpful, have tried everything.
Message posted on 26 Nov 2024 12:06 PM - last edited: 26 Nov 2024 12:07 PM
That's a vintage model from 2016.
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to disable the 5Ghz WiFi band.
Message posted on 26 Nov 2024 02:07 PM
Have tried WPA3 to WPA2 it doesn't help.
Where do i find the 5ghz info and what do I change it to?
