15 Jul 2024 02:00 PM
Hi all
Had my LG ThinQ washer a while now and had no problems connecting it to the previous Sky router. I now have one of the bigger white hubs used for the Ultrafast BB but have lost access to the washer.
I have mobility issues so that was the reason I got this washer.
In the LG app it's saying it needs only 2.4
GHZ wifi. I know the hub automatically switches, but had the previous one split into 2 SSIDs. Is there any way I can get the washer to connect?
When I scan for Wifi connections, it's only picking up my printer.
TiA
15 Jul 2024 05:50 PM
Posted by a Superuser, not a Sky employee. Find out moreIn the My Sky app under advanced WiFi settings you can disable the 5ghz radio temporarily.
16 Jul 2024 11:36 AM
@jamesn123 have tried that but the washer still thinks it's on the network and "hasn't been used since May."
Is there any way of booting a device off the network without having to unplug it? It's under the worktop 😫
16 Jul 2024 01:39 PM
Posted by a Superuser, not a Sky employee. Find out more@tangledcookies you could try turning off your house mains for a few seconds if the washer's plug is inaccessible and there isnt a fused switch above the work surface.as there should be.
16 Jul 2024 01:40 PM
Thanks but it's an old house.
16 Jul 2024 01:41 PM
It's an old house lol
