30 Oct 2022 03:50 PM
After decades with PlusNet, we decided reently to hange to Sky for broadband, retaining our existing BT telepone-nuber. The change is due to occur in a week or so. To our dismay, we have just been told by BT that they are sorry that we are leavgig. Leaving ? Why ?
30 Oct 2022 03:53 PM
Only thing i can think is plusnet is owned by BT
30 Oct 2022 03:54 PM - last edited: 30 Oct 2022 03:56 PM
Posted by a Superuser, not a Sky employee. Find out moreSky will be taking over your Broadband and your landline will be with Sky Talk. plusnet's parent company are BT.
30 Oct 2022 03:57 PM
Posted by a Superuser, not a Sky employee. Find out more@paieye Did your Telephone service get supplied by BT with plusnet oroviding the broadband side? Years ago it was possible to have one provider for the Telephone line and one for the broadband, although much less common these days as one provider tends to supply both.
30 Oct 2022 04:39 PM
Thank you, Yes, when we moved here 16 years ago, BT already supplied the telephone-nummber/line. We then changed our PlusNet account from our previous address to this one. Are you saying that having an ISP different from the line-provider is no longer a possibility ?
30 Oct 2022 04:44 PM
Yes that is correct
30 Oct 2022 04:56 PM
Thank you. Can I presume that the change of telephone-providere odes not entail a change of telephonoe-number ?
30 Oct 2022 05:01 PM
Posted by a Superuser, not a Sky employee. Find out more@paieyeWould say in most instances if you have asked to keep your number this should happen. Unless the provider you are leaving has a good reason not to let this happen. You can ask Sky if you are able to keep your number during the ordering process.
30 Oct 2022 05:04 PM
Yes, I did specify that we were to retain the number. Thank you again for your very prompt help.
30 Oct 2022 05:14 PM
Its worth pointing out that there is no guarantee you will keep the number - it'd be a lot more likely if both phone and broadband were with the same supplier (ie Plusnet or BT rather than split between them) - and once "lost" its often impossible to get it back as it'll be outwith Sky's number pool.
Basically every telecoms company have telephone number ranges assigned to them (their "pool") and if the number isn't ported across from one teleco to another then you've lost it. Its sometimes possible to "get it back" but it isn't a quick process by any means.
30 Oct 2022 05:16 PM
This is causing me much anxiety. On top of that, I can find no way of reaching Sky by email to get some answers.
30 Oct 2022 05:18 PM
Posted by a Superuser, not a Sky employee. Find out moreSky don't use email as a general method of communication. Give Sky a call. If you already have a Sky Mobile call free by just dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK: Scroll down and click on ‘Need more help’ and it provides an 0333 number.
ROI: change the flag in the very bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides an 0818 number.
(The forum filters don’t like us typing the digits in full).
As with most large companies the start will be automated but stay on the line and don’t hang up if you’re prompted to. Depending on your particular issue the operating times of the various departments may differ.
30 Oct 2022 05:29 PM
Thank you again, outstandingly helpful
