11
This discussion topic has been answered Discussion topic: Keeping landline number when transferring to SKY Broadband
This message was authored by: Gareth70
I’m currently moving from Talk Talk to Sky Broadband and I’ve been told I can’t keep my existing landline telephone number - which is a problem for me. Does anyone know if there's a way around this? Thanks.
This message was authored by: mae-3 Answer
Re: Keeping landline number when transferring to SKY Broadband
@Gareth70
You need to push the bit about number portability because that is the Ofcom regulation that states that fact.
@Gareth70
While providers often have different policies, you might try a few steps to retain your existing landline number when switching from TalkTalk to Sky Broadband:
  1. Contact Sky: Reach out to Sky’s customer service directly and explain your situation. They might have a process for transferring or "porting" your current number, especially if you're within the same geographical area.
  2. Double Check with TalkTalk: Confirm with TalkTalk if there are any constraints on their end that prevent number portability, and clarify any additional options they might provide.
  3. Number Portability Request: It may be worth formally requesting number portability with both providers, as by regulation in many regions, they are obligated to facilitate this unless specific technical or regional factors impede it.
  4. Regulatory Guidelines: Look into local regulations regarding number portability as these sometimes can provide additional leverage if your current provider is noncompliant.
  5. Use Third-Party Services: Some third-party services offer number portability solutions by porting your number to a VoIP service and then connecting it to your new provider.
Contact both service providers as soon as possible to explore these options, as the process can require some time and coordination.
Avatar for Gareth70
Thanks Mae-3. This is very helpful. I've tried talking to both Sky & Talk Talk with no luck. I'll have another go before mving onto your other suggestions.
@Gareth70
Avatar for Gareth70
@mae-3
Thanks. I'll definitely refer to 'porting' my existing number and see what happens.
@Gareth70
According to Ofcom's regulations, consumers in the UK generally have the right under "Number Portability" (General Condition B3) and "Switching" (General Condition C7) rules, which allow them to transfer their landline numbers when changing providers. If you request it, the process should generally be free of charge according to the regulations, and your new provider can help arrange the switch.
@Gareth70
And you can reach out to Ofcom for further guidance or resolution options if Sky & TalkTalk don't comply.
This message was authored by: james+h+connolly
How did that go in the end ?
This message was authored by: Dave399
I'm having a similar issue with Sky albeit my previous supplier was Vodafone. I'm trying all the previous suggestions and also quoted the OFCOM rules. In summary :
'You can keep your existing landline telephone number when you switch. This is known as number 'porting'. If you want to keep your number, let your new provider know. You can request to keep your old phone number for free even if you have already cancelled your previous service (as long as you request this within one month of cancelling).'
I've still not had any success with Sky.
@Dave399 to understand the issue with your number transfer was your old Vodafone connection via Openreach or City Fibre? Second question is the new Sky connection going to be with Openreach to City Fibre?
Sky's relationship with City Fibre is pretty newxand it is **bleep**ible there are still,some system issues to be sorted. Number transfers between Openreach lines however normally go smoothly
The landline is provided by Openreach both before and after my move to Sky.
@Dave399 then all I can suggest is to raise a formal complaint to at least get an explanation see How to make a Sky complaint | Sky Help | Sky.com
