Discussion topic: Just about to have Fibre go live
This message was authored by LGUser This message was authored by: LGUser
We just had Openreach install the fibre cable and the box on the wall. Once the box light turns green, it's live and I should be able to then call Sky to get my Internet sorted.
My question is, once I call Sky and get it sorted, do they overnight the modem? Does anyone from Sky have to come to make sure it's working?
Re: Just about to have Fibre go live
@LGUserWas this outside work or inside work that was done?
LGUser
Both. We had the cables run under the residence. Last week we had the cable brought inside. Today we had the cales under the residence checked and the box to plug in the fibre cable was installed inside and the fibre cable plugged in. The bar code was scanned and we were told all we have to do now is wait for the red light to turn green and then we can call whichever ISP we want as it should be in their database that we are live.
Openreach are supposed to let the ISP know in advance, so that the router is already there:  sometimes I think they just get ahead of themselves though.  No-one from the ISP needs to attend the address.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
I thought the PON light is only on once the service from the ISP is active, so it won't come on until you have a connection from your chosen ISP (which I believe, for you is Sky).
I could be incorrect though about the light and when it comes on.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
This message was authored by Ragz2020 This message was authored by: Ragz2020
How many months/weeks did this take?
@Skull+TreatyMines was on, but the provision of the ONT had been done wrong, as the town I stay in is in 2 countries which make up Britain.
Oh yes, I recall you saying about that mix up @Highlinder
I thought I may have been incorrect re the PON light. I'm sure @LGUser will keep us posted tomorrow.
BT have a little guide on the lights here , I read that it's on when connected to the service (in the example given, the BT exchange) again, I may not be right.
LGUser
Openreach did not let the ISPs know in advance. What I was told waas that that scan the bar code and then the information that the fibre is live goes out tot he ISPs.
Thing is, there was no active FTTP until today. I'm not waiting for Sky to say it's OK to get service.
LGUser
The fibre modem we have is a Nokia ONT model number G-010G-R V2.
LGUser
Yes, I will keep this thread updated as to what happens.
@LGUserI had Sky out to install my ONT, had seen that is what was happening to give a greater scope for to get more people connected to FTTP.
LGUser
Sky won't send someone out to see that the modem is active even though I tell them so. They need to see it in their database. So I'm hoping that it gets in the database tomorrow or Wednesday.
@LGUserThe broadband engineer I had did scan the barcode on the ONT, it goes against the job number so that it can then activate it on their systems. Looks like that is what Openreach did for you today, but not sure when the information will go live for you.
