Discussion topic: Ive just had the sky max fitted but my Wifi is off every morning. Any ideas?
This message was authored by: Patgarner
Just had Sky Max fibre optic broadband fitted but every morning my wifi is off and it takes hours for its name to appear on the wifi in area list. Its like it just doesnt see it but then after a couple of hours it will appear. Ive tried everything. Turned off and on again, the hub box has the white light at the front and i have a booster, but it still drops for hours
Re: Ive just had the sky max fitted but my Wifi is off every morning. Any ideas?
@Patgarner when you add a pod extender the system takes 24 hours or so to optimise so you may have to give it more time. Is it specific devices thst dont pick up,the SSID initially or every device? If it is specific devices ensure you have set them to trust the connection so they connect automatically.
That said  if the issue continues get Sky to send an engineer to check the set up.
Avatar for Patgarner
Hi, thanks for the reply. Its every device which tries to connect via wifi. I'll give it a couple more days to bed in then I'll contact sky. Thank you
