Discussion topic: Issues with Wifi- My sky app says no problem but have an orange light
This message was authored by: HannahG92
hello i'm having issues with our internet every single day. The app says there's no issues and everything is connected but the box is showing an orange light. I've tried to reset the box but it makes no difference
please help as i'm on the verge of leaving sky to go elsewhere!
Re: Issues with Wifi- My sky app says no problem but have an orange light
@HannahG92
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
