8
This discussion topic has been answered Discussion topic: Issues with Wi-Fi on iPad. Finds the Wi-Fi but will not connect
This message was authored by: Bazzaman27
I can no longer use my iPad for emails., browser etc.
Re: Issues with Wi-Fi on iPad. Finds the Wi-Fi but will not connect
@Bazzaman27 I find the following works first tell the iPad to forget the Sky connection. Then power down the iPad by holding the  side button and ine of the volume buttons until the power slide shows on scren. Once shut down reboot the iPad and once fully rebooted add the connectioon again. Ifvthe second iPad is brought near the girst it should pick up the log-in details from the first one.
@Bazzaman27
Have you tried a reboot of your broadband hub at the mains,and also
your iPad, if that doesn't fix it what happens when you try to connect it ?
Avatar for Bazzaman27
Tried that. Also Reset Network Settings still no joy
@Bazzaman27 Do you have other devices that are connected and working fine, and is this just a new condition that is on the iPad or has it never connected before!
@caesarome wrote:
@Bazzaman27
Other devices connected and are working
@Bazzaman27 Was a two part question!
This message was authored by: Wardy4
Wi fi issues
