26 Jun 2022 03:33 PM
Simple question by a bit of a newbie.
26 Jun 2022 03:40 PM
Posted by a Superuser, not a Sky employee. Find out more@Number+FourDon't you hate it when you have typed a fairly long reply and someone moves the post and the answer fails.
However in summary you don't have to have a telephone but you need someway of getting the internet to your house.
26 Jun 2022 04:08 PM
Posted by a Superuser, not a Sky employee. Find out more@Number+FourYou need a landline number in order to have broadband. But you can go on to pay-as-you-go with Sky and if you have no phone plugged in then no calls are made. The line rental is bundled in with the broadband now.
26 Jun 2022 04:20 PM
@Number+Four only with virgin media i know you dont need a landline to have broadband as you can get broadband only on its own with virgin media
27 Jun 2022 08:00 AM
Although you do need one of their coaxial cables which serves the same purpose.
27 Jun 2022 08:05 AM - last edited: 27 Jun 2022 08:11 AM
'landline' is rather an outdated concept. Fixed-line broadband requires there to be a physical bearer of some kind at the address which the ISP uses to deliver data: this might be a 'phone' line (copper pair), fibre optic cable or coaxial copper cable.
Non-fixed-line options are 3/4/5G cellular data, WISP and satellite (geosynchronous or Starlink).
None of these is necessarily linked to the voice call service which used to define a 'landline'.
27 Jun 2022 09:28 AM
Posted by a Superuser, not a Sky employee. Find out moreWith BT you can have broadband with or without a telephone however the cost difference is marginal.
