Discussion topic: Is WIfi 6 automatically used with Sky WiFi Max Hub?
Message posted on 23 Apr 2024 06:06 PM
I have an iPhone 15 Pro max which has WiFi 6/E compatibility, will my iPhone automatically connect to Sky's WiFi Max Hubs WiFi 6?
Do I need to change or turn on a setting to make use of WiFi 6 on my Hub for my iPhone to connect using WiFi 6? I can't see any setting for WiFi 6 on the Hubs settings page.
basicly , will my iPhone 15 use WiFi 6 Automatically?
Apologies for the noob question.
Message posted on 23 Apr 2024 06:36 PM
Re: Is WIfi 6 automatically used with Sky WiFi Max Hub?
@Barry1506
it should just use it automatically.
On Andriod you get a helpful little '6' next to the WiFi signal bars that tells you. I dont think Apple does the same for their devices.
Message posted on 23 Apr 2024 06:38 PM
Thank you for you're reply, it seems like Apple like to keep it a secret if you're using WiFi 6 it seems from my research. But thanks again!😊
