3
This discussion topic has been answered Discussion topic: Is Sky broadband better tha TalkTalk 150 fibre?
This message was authored by: Geoff1951C
I have TalkTalk150 fibre, is Sky broadband better?
Re: Is Sky broadband better tha TalkTalk 150 fibre?
@Geoff1951C
'Better' in what respect?
Broadband at a particular speed band on the Openreach network is all the same wholesale service: differences are largely in ISP hardware and customer support offerings.
@Geoff1951C
Avatar for Geoff1951C
Better as in, dropping out, download speed varies from hour to hour during the day.
Would 86 bebworth changing provider?
@Geoff1951C assuming you are talking about aTalk Talk service over an Openreach line then your experience is likely to be broadly the same as both companies are effectively reselling the same Openreach product. The only difference is from the exchange where they use different back haul networks. Both networks are actually highly reliable most faults occur in the Openreach connection so if your line has issues it will move with you. Neitherccompany has major issues with download speeds dropping at busy times.
Overall Ofcom  rate Sky above Talk Talk on complaint numbers but that doesn't help if you are one of the unlucky few whose Sky line causes issues.
