Discussion topic: Is Sky Fibre compatible with a TP-Link Deco XE75 Pro AXE5400 Whole Home Tri-Band Mesh Wi-Fi 6E Syst
This message was authored by: Wadadli
I've bought a TP-Link Deco XE75 Pro AXE5400 Whole Home Tri-Band Mesh Wi-Fi 6E System, to link into my Sky router, but I don't think it's working as it should be.  What should I check please?
Re: Is Sky Fibre compatible with a TP-Link Deco XE75 Pro AXE5400 Whole Home Tri-Band Mesh Wi-Fi 6E
@Wadadli
What makes you think it isnt working right? Whats happening?
I am NOT a Sky Employee
Avatar for Wadadli
I think the fact the Sky router is broadcasting a wifi signal, and the TP is broadcasting a wifi signal I get the impression the latter is being interfered with by the Sky signal.  Should I turn the Sky router wifi off?  Is that even possible?
@Wadadli
Yes you shouldnt really run two routers together in close proximity. You can disable the WiFi on the Sky hubs settings.
Avatar for Wadadli
OK, thank you.
So I want to set the TP up with the same SSID & password as the Sky router, so I don't have to reset all the SSIDs & passwords on all devices, and providing I disable the Sky router this should be fine, right?
@Wadadli
Yep that should be fine
Avatar for Wadadli
Thank you for your advice 🙏
This message was authored by: Mike237
If my sky glass to is in another room and connects to the sky router wirelessly can I turn off the WiFi signal on the sky router and connect the sky glass to (and everything else) to the to link deco xe95? Thank you!
Sorry  - the last post auto corrected 'tv' and 'tp' to 'to' hope that did not make it too confusing.
