Discussion topic: Is My Internet Banded?
This message was authored by geobrad This message was authored by: geobrad
Good Afternoon,
I have a prepayment electricity meter, unfortunalty i forgot to top up twice in the past couple of  weeks and the power went off.  Am thinking this has resulted in my line getting banded, so i just wait it out for it to reset?
Re: Is My Internet Banded?
@geobrad
Could you run tests on your my sky app and post the info in more about your connection
geobrad
@geobrad
You are 29Mbps with a guarantee of 39Mbps. In my opinion if it had been the meter then all times would have reset to the same  .
Call sky on 150 from your landline or
zero three three three seven five nine one zero one eight from any other phone and ask them to run a line test
Or if in Ireland
Call sky ireland on
08.185.00.27.2
Remove all the full stops
@geobrad
Its worth waiting 2 weeks to see if the line brings itself back. If not you have the right to call Sky and get them to investigate as you are below the minimum speed for your line.
I am NOT a Sky Employee
geobrad
Happy days!!! not had a chance to contact sky get, but it reset back to 44 meg overnight
