Discussion topic: Ip address
This message was authored by ero1960 This message was authored by: ero1960
Ip address
I use a camera security system which I connect to via an app. I'm currently away from home and can't access my cameras, someone has suggested it's because sky will have changed my IP address and so the app stops working. Any ideas on how I can remedy would be appreciated
Re: Ip address
@ero1960 Sky like almost every other isp use dynamic IP addressing.
The solution is to use a Dynamic DNS service. Check with your camera supplier as to which services their software supports. Your Sky hub supports three namely dyndns.org, noip.com and dyns.cx. Choose a service that appears on both lists and set up an account. Then enter the account details in the Advanced/Dynamic DNS page of hub's interface. Then when the IP address changes the hub tells the service which then tells the camera app when you connect.
ero1960
Re: Ip address
Hi, thanks for the reply, the camera service, xprotect, does use dyndns.org but I still seem to have these issues now and again
Re: Ip address
@ero1960 check  you have set up your personal account details for dyndns.org in the hub? Even if you have check the hub as they can be lost if the hub has been reset
Sky stopped issuing static IP addresses years ago. Other ISPs still do if asked I believe Zen do but check.
