This discussion topic has been answered Discussion topic: IoT smartlife plugs going offline on Sky Max SR213 router
Message posted on 02 Dec 2025 10:50 PM
Message posted on 04 Dec 2025 08:30 PM
Yep, 48hr later, and it seems downgrading to WPA2 has solved fhe problem, at least so far (and this is by far the longest they've stayed online).
Will report back if it fails, but at least for me, this seems to be the fix.
Message posted on 02 Dec 2025 11:11 PM - last edited: 02 Dec 2025 11:18 PM
Re: IoT smartlife plugs going offline on Sky Max SR213 router
@triptogenetica You want control that you need then get your own third part router, you can use your own 2.4Ghz extender that will work just as well! WPA2 would be the way to go also stability of the wireless may improve, for sure none off your Iot devices are wifi 6 in the slightest! Tapo P110 work really good, never had a problem and have 8 connected over various mesh positions!
Message posted on 02 Dec 2025 11:30 PM
Thanks, yes, I like the Tapo and Kasa ones too.
But the Smartlife ones work fine with other routers, just not this Sky one!
Will report back after maybe 24-48hr at WPA2, in case that's the answer.
Message posted on 04 Dec 2025 09:16 PM
@triptogenetica Please get the downgrading out off your head, there is nothing wrong with a WPA2-PSK secure wireless wifi network on a home environment, you can thank the stupid fruit flavoured company for all the confusion!
You want WPA3 then every device that does not have it will required to be changed out in your home, no other way to do it!
