07 Feb 2023 05:24 PM
I wonder if someone can help. At the moment my download speed is 20Mbs, when I did a internet speed provided by the new job recruit. I have applied for this job to WFH as a customer service but they are asking the speed of 25Mbs. I have tried to get in touch with sky, but its not helping at all. Is there a number which takes me directly to them to see whether they are able to increase this?
07 Feb 2023 05:32 PM - last edited: 07 Feb 2023 05:43 PM
@Atelini do you know what broadband package you currently have ? as that may provide some clues as to wether you can upgrade to a faster speed or not
you could also provide your router stats as per the link below
07 Feb 2023 05:40 PM
Posted by a Superuser, not a Sky employee. Find out more@Atelini
It may also be that your speed is limited due to your connectiom method. Are you connecting via WiFi or ethernet?
07 Feb 2023 05:44 PM
aha! that makes sense. Im currently connected by wifi.
07 Feb 2023 05:54 PM
I'm currently on Sky Broadband Superfast 35. I have tried to opt for a the ultrafast, this is the next one up. It's currently not available in my area, but I have put my address down to be registered.
07 Feb 2023 06:06 PM
Posted by a Superuser, not a Sky employee. Find out moreConnect with an ethernet cable and re-run the test. If you are going to be WFH and making calls for CS you'll likely need to connect via an ethernet cable permanently anyway to ensure you dont drop connection/calls.
07 Feb 2023 06:07 PM
Thank you, I will do that.
