Discussion topic: Internet not working properly - very low speeds
This message was authored by: AshleighT1993
Hi, was having issues getting online during the night and have tried again this morning and still the same. I've just ran a speed test and got very poor results!
Re: Internet not working properly - very low speeds
@AshleighT1993 if running speed tests on a device connected by WiFi you often just end up testing the WiFi part of the transfer rather than the speed of your broadband as that is slower. Loss of speed in the evenings is typically caused by increased interference from your neighbours' networks.
While rebooting your Skybhub can help the best solution is to improve the WiFi signal strength in your home. First check your hub is out in the open on a surface above obstructions like radiators and furniture. Beyond thst things get more complicated and potentially expensive.
This message was authored by: Hannah120
Same !! Last night and again this morning !!
@Hannah120 with over 6 million Sky Broadband customers lots of people have similar issues but it doesnt normally mean they have the same cause.
