Discussion topic: Internet keeps going to amber
This message was authored by jayp28 This message was authored by: jayp28
My Internet today keeps disconnecting, its so annoying the box keeps jumping from green to Amber it tells me to run a check which I do says nothing is wrong but obviously there is because it wouldn't keep doing it otherwise, then it goes back green and says I have to sign back in, its happened around 5 times in the last 2 hrs
Re: Internet keeps going to amber
@jayp28
Can you post your hub stats
@jayp28 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
jayp28
jayp28
Will give it another try now thank-you
jayp28
@cookiemonsteruk I have done this and it says everything's fine yet give it a while and it will go off again ?
jayp28
@Highlinder I've done this a few times today and just re run it, it's telling me everything is good ? But it still keeps disconnecting
@jayp28Do the test when it goes down and not when it is back up.
