Discussion topic: Internet keeps dropping out, 2 days now , i,ve reset router etc ,still having problems
This message was authored by: Hardys9466
As stated , internet keeps dropping, 2 days now , router reset etc still having problems , this isn't the first time this has happenend
PS Hardy
Re: Internet keeps dropping out, 2 days now , i,ve reset router etc ,still having problems
@Hardys9466
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
