Discussion topic: Internet keeps cutting out on regularly basis daily
This message was authored by: MatthewIC
Daily the internet cuts out cutting connections to both myself and my husbands work computers - this has been happening over a few months
Re: Internet keeps cutting out on regularly basis daily
@MatthewIC You need to start by the following series off test, and if no joy then call sky to have them check from there end.
Try running the line test here to see if any faults are found:
