Discussion topic: Internet drops every few minutes or so.
This message was authored by Dosha This message was authored by: Dosha
Over the last few working days the internet has dropped off every few minutes. It's been especially bad today.  I ran the check and it gave a windows error message twice because there was no broadband. The broadband came back and the checker told me all was well.
Well it isn't well and very annoying.  They have been working in my area and I don't know if that is causing the outage.
I had problems with phone last 2 weeks and that seems oK, but  broadband is the problem now.
Any ideas how I find out what is causing this?  I got a new hub last week and that seemed to fix the phone problem, but I do think it is the line working that is causing this broadband problem
Re: Internet drops every few minutes or so.
@Dosha
Can you post your hub stats
Dosha
Is this right?
Broadband Connected
WiFi Enabled
WiFi Network Name (SSID) SKYPHLFT
WiFi Network Visible Yes
Current WiFi Channel 11 (2.4 GHz), 36 (5 GHz)
WiFi Encryption WPA2-PSK
VoiceConnected
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Dosha wrote:
Is this right?
Broadband Connected
WiFi Enabled
VoiceConnected
@Dosha
No, you'll need to follow the guide @cookiemonsteruk posted, right to the end; then you'll see the stats that are needed.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
@Dosha
You need to click on maintenance along the top and sign in with :-
Username      admin
Password        sky or wifi password on the back of the hub
Then click show statistics at the bottom of the page
Dosha
Followed the instructions and tried to enter my username and password.  It wouldn't accept either my password or the suggested 'admin' 'sky'.
Gave error message
401 Unauthorised
Authorisation required.
I've tried several times without success and I am no slouch with IT.
The men have packed up for the day and it all seems stable again, until tomorrow.
Dosha
System Detailshelp
ManufacturerSky
ModelSR203
Firmware Version7.02.0501.R
Modemhelp
Modem StatusConnected
DownStream Connection Speed0
UpStream Connection Speed0
IPv6 Loopback Address[content removed]
Broadband Porthelp
MAC Address[content removed]
IPv4 Address[content removed]
Network TypeMER
IPv4 Subnet Mask255.255.252.0
Gateway IPv4 Address[content removed]
IPv4 Domain Name Server[content removed]
Gateway IPv6 Addressfe80::22
IPv6 Domain Name Server
IPv6 Global Address[content removed]
IPv6 Link Local Address[content removed]
IPv6 Delegated Prefix[content removed]
WAN Porthelp
WAN Port StatusConnected
Port DetailPort 4
LAN Porthelp
IPv4 Address192.168.0.1
DHCPv4On
IPv4 Subnet Mask255.255.255.0
IPv6 ULA[content removed]
DHCPv6On
WiFi Porthelp
Name (SSID) [content removed]
Region Europe
Current Channel 11 (2.4 GHz), 36 (5 GHz)
WiFi AP Enabled
Broadcast Name Yes
Voicehelp
Voice StatusConnected
Moderator note: personally identifiable information removed
