28 Mar 2024 11:21 AM
Hi,
For the past few weeks, our sky broadband has kept dropping out and then reconnecting after about a minute.
Separately, the wi-fi signal becomes very slow - about 1mbps even though the upload was still 4mbps.
I've turned the router on and off a couple of times. In all the years before this we haven't had any problems.
Router stats below:
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN Down 0 0 0 0 0 00:00:00 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 513932 233882 0 0 0 14:27:46 WLAN (5 GHz) Up 23819813 16048482 0 2 0 14:27:44
28 Mar 2024 11:41 AM
Posted by a Superuser, not a Sky employee. Find out more@johnmccon Going by your router stats shows your connection down. Have you tried to run the broadband test to see if it finds a external issue.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
