This discussion topic has been answered Discussion topic: Internet and voice are down
Message posted on 04 Jul 2025 12:33 AM
WiFi suddenly stopped working. The voice and internet lights have gone orange. I have restarted the router and checked health online and it says there are no issues
Message posted on 04 Jul 2025 12:41 AM
Once you run the service checker and get all green ticks then click on your broadband speed and run the test my broadband/test my connection in the blue box . That should update the previous service checker and hopefully allow you to book an engineer
Otherwise you will need to call sky in the morning
Message posted on 04 Jul 2025 01:05 AM
Re: Internet and voice are down
Same problem here at pretty much the exact same time.
Service check is saying no issues. Unplugging and restarting making no difference!
Message posted on 04 Jul 2025 03:51 AM
When there are issues between midnight and 7am it's possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If not then also try the post marked as the answer.
