Discussion topic: Internet and Wifi Down in NW3 | 15 July 2025 20.52
Message posted on 15 Jul 2025 08:56 PM
Hiya it's 20.53 on 15 July 2025 - No Internet in London NW3. Alas, anybody else?
Message posted on 15 Jul 2025 08:58 PM
							Re: Internet and Wifi Down in NW3 | 15 July 2025 20.52
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it.  The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Message posted on 15 Jul 2025 09:01 PM
Thanks. I have done all that. No luck been in an interactive loop for hours. currenlty running on my phone's hot spot. Any idea on the fix? Says DAYS is this true?
Message posted on 15 Jul 2025 09:26 PM - last edited: 15 Jul 2025 09:30 PM
The boilerplate text there is frankly unhelpful: it is unrelated to any specific incident and actually refers to a fix within two working days (starting the following working day morning after an issue is logged by an ISP) being the Openreach target for domestic broadband fault resolution.
