6
This discussion topic has been answered Discussion topic: Internet and TV and phone drop out every night virtually
This message was authored by: Rosie865427
My connection goes down most evenings around 9pm - WHY?
I know people say its 'maintenance' but I'm sorry - surely Sky do not do maintenance virtually every night.
I need an explanation please.
I am even considering moving suppliers it is so predictable when it is going to happen!
Re: Internet and TV and phone drop out every night virtually
@Rosie865427 it is definitely not maintenance at 9pm so needs checking out.
One of the most common issue is WiFi interference from your neighbour's networks which will increase at peak times. This is highly likely if you live in a flat etc. Rebooting the hub can helpmas that forces the hub to find the least congested channelsbut the longterm solution is better wifi kit. However there can be other causes somthink about what else happens in your home at the sametime as running a microwave can knock out the connection if the oven is faulty
Shifting isp is actually highly unlikely to help as these issues are very rarely caused by issues in Sky's network they are either in your home or in the Openreach line. If you have a black Sky hub please post the connection stats taken when the connection has been OK for a while see Sky Hub statistics
@Rosie865427
Too early for essential maintenance. Does anything else switch on or off at the same time?
Avatar for Rosie865427
Hi there.
Nothing else drops out, just the stuff I have with Sky.
@Daniel0210 if other eevuces are remaining connected to the internet it rules out the broadband connection. What Sky devices are affected?
Sorry my mistake - my Roku stick (which uses internet) drops out, my Smart TV streaming drops out etc., etc. Everything related to the broadband connection and my land line drops out.
Hi!
Here are my statistics since the drop out last night.
Any ideas?
Thank You
