Discussion topic: Internet Connectivity Issues
This message was authored by rogue1216 This message was authored by: rogue1216
Hi,
We seem to be having connectivity issue. The internet doesnt drop, but will cause issues with games and streaming. In the router log, the router seems to be renewing its IP address alot.
Any help would be great.
Please see below for the Router Log and Stats. I have had to edit the log, as the forum wouldnt allow me to paste in with all the same dates and times.
15:44:20 syslog: Lease renewed 3600 ip
16:11:02 syslog: Lease renewed 3600 ip
16:30:05 syslog: Send out NTP request to ntp1.isp.sky.com
16:30:05 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
16:30:05 syslog: System time is up to date
16:40:43 syslog: Lease renewed 3600 ip
17:13:23 syslog: Lease renewed 3600 ip
17:39:11 syslog: Lease renewed 3600 ip
18:04:05 syslog: Lease renewed 3600 ip
18:34:39 syslog: Lease renewed 3600 ip
18:34:39 syslog: Send out NTP request to ntp1.isp.sky.com
18:34:39 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
18:34:39 syslog: System time is up to date
18:34:39 syslog: TR69: Connect to unknown ACS
18:34:54 syslog: TR69: Close ACS Connection
19:04:02 syslog: Lease renewed 3600 ip
19:36:07 syslog: Lease renewed 3600 ip
20:05:31 syslog: Lease renewed 3600 ip
20:40:11 syslog: Administrator login successful from IP:.
20:40:35 syslog: Lease renewed 3600 ip
20:40:35 syslog: Send out NTP request to ntp1.isp.sky.com
20:40:34 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
20:40:34 syslog: System time is up to date
20:51:02 syslog: Administrator login successful from IP:.
20:56:11 syslog: Administrator logged out from IP address.
21:11:25 syslog: Lease renewed 3600 ip
21:47:05 syslog: Lease renewed 3600 ip
22:17:58 syslog: Lease renewed 3600 ip
22:46:11 syslog: Send out NTP request to ntp1.isp.sky.com
22:46:11 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
22:46:12 syslog: System time is up to date
22:52:44 syslog: Lease renewed 3600 ip
23:25:06 syslog: Lease renewed 3600 ip
23:54:12 syslog: Lease renewed 3600 ip
00:19:42 syslog: Lease renewed 3600 ip
00:45:48 syslog: Lease renewed 3600 ip
00:50:50 syslog: Send out NTP request to ntp1.isp.sky.com
00:50:49 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
00:50:49 syslog: System time is up to date
01:20:15 syslog: Lease renewed 3600 ip
01:47:15 syslog: Lease renewed 3600 ip
02:19:01 syslog: Lease renewed 3600 ip
02:46:19 syslog: Lease renewed 3600 ip
03:06:22 syslog: Send out NTP request to ntp1.isp.sky.com
03:06:22 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
03:06:22 syslog: System time is up to date
03:21:40 syslog: Lease renewed 3600 ip
03:55:32 syslog: Lease renewed 3600 ip
04:20:08 syslog: Lease renewed 3600 ip
04:45:38 syslog: Lease renewed 3600 ip
05:17:42 syslog: Lease renewed 3600 ip
05:17:42 syslog: Send out NTP request to ntp1.isp.sky.com
05:17:42 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
05:17:42 syslog: System time is up to date
05:44:24 syslog: Lease renewed 3600 ip
05:44:24 syslog: TR69: Connect to unknown ACS
05:44:39 syslog: TR69: Close ACS Connection
06:15:33 syslog: Administrator login successful from IP:.
06:18:16 syslog: Lease renewed 3600 ip
06:20:50 syslog: Administrator logged out from IP address .
06:32:18 syslog: TR69: Connect to unknown ACS
06:32:32 syslog: TR69: Close ACS Connection
06:32:43 syslog: TR69: Connect to unknown ACS
06:33:02 syslog: TR69: Close ACS Connection
06:38:28 syslog: Administrator login successful from IP:.
06:44:04 syslog: Lease renewed 3600 ip
06:44:14 syslog: Administrator logged out from IP address.
06:52:40 syslog: Administrator login successful from IP:.
06:55:10 syslog: TR69: Connect to unknown ACS
06:55:23 syslog: TR69: Close ACS Connection
06:55:31 syslog: TR69: Connect to unknown ACS
06:55:49 syslog: TR69: Close ACS Connection
06:57:28 syslog: TR69: Connect to unknown ACS
06:57:42 syslog: Administrator logged out from IP address.
06:57:44 syslog: TR69: Close ACS Connection
06:57:53 syslog: TR69: Connect to unknown ACS
06:58:15 syslog: TR69: Close ACS Connection
07:00:25 syslog: TR69: Connect to unknown ACS
07:00:41 syslog: TR69: Close ACS Connection
07:00:50 syslog: TR69: Connect to unknown ACS
07:01:12 syslog: TR69: Close ACS Connection
07:03:04 syslog: Administrator login successful from IP:.
07:07:53 syslog: TR69: Connect to unknown ACS
07:08:06 syslog: Administrator logged out from IP address.
07:08:09 syslog: TR69: Close ACS Connection
07:08:19 syslog: TR69: Connect to unknown ACS
07:08:40 syslog: TR69: Close ACS Connection
07:16:44 syslog: Lease renewed 3600 ip
07:21:19 syslog: TR69: Connect to unknown ACS
07:21:38 syslog: TR69: Close ACS Connection
07:31:07 syslog: Administrator login successful from IP:.
Router Statistics
System Up Time: 47:52:03
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 44012314 112596439 0 9606 11965 47:50:32 LAN Up 9858898 7361103 0 130818 39388 47:52:03 WLAN (2.4 GHz) Up 4480950 1417184 0 25833 7204 47:49:33 WLAN (5 GHz) Up 108273470 40261998 144 0 0 47:45:41
Broadband Link Downstream Upstream Connection Speed (Kbps) 79999 20000 Line Attenuation (dB) DS1:3.1    DS2:6.1    DS3:9.2 US0:1.1    US1:3.6    US2:4.6 Noise Margin (dB) DS1:13.5    DS2:13.4    DS3:13.4 US0:9.7    US1:9.9    US2:9.6
Re: Internet Connectivity Issues
@rogue1216 nothing apparently wrong with the stats you are on a very short line with your hub connecting at 80Mb/s down and 20Mb/s up. The log looks a little odd perhaps someone can comment on the ACS events as they esacapeme. The IP address renewals are completly normal and are background events.
There have been a number of reports of DNS issues etc recently which might be affecting you. The cause is thought to be the server you are using to connect to Sky's network being faulty. There multiple units at each location so powering down your hub for a few minutes should force a change to your public IP address and hopefully connect you to a server that is working properly.
rogue1216
Hi Chrisee,
Thanks for you reply, i just thought that the amount of times the router is renewing the ip was a bit suspect.
Any ideas about TR69 ACS messages?
Yeah, we are almost next door to the local exchange.
Many Thanks
That is the router reporting back to Sky
I am NOT a Sky Employee
