Discussion topic: Intermittent connection dropping
This message was authored by: ianwade
keep losing wifi connection
Re: Intermittent connection dropping
@ianwade do you mean wifi ie the signal in your home or the broadband connection yo your hub? The lights on the hub will tell you if its the latter see https://www.sky.com/help/articles/hub-lights-explained-start for how to tell and what to do.
Avatar for ianwade
thanks I will check it out
