3
This discussion topic has been answered Discussion topic: Intermittent WiFi on sky glass tv
This message was authored by: Jbvhmcg
The TV seems to keep dropping off the WiFi then has to be reset and connects again straight away via the WPS button.
I'm going to attach the stats when I can log in! Thanks
This message was authored by: cookiemonsteruk Answer
Re: Intermittent WiFi on sky glass tv
@Jbvhmcg
There is no traffic at all on 5ghz and minimum traffic on ethernet meaning that 2.4ghz wifi is running everything over the last 300 hours. 2.4 ghz wifi is prone to interference from other wifi networks and certain household appliances. Consider using 5ghz wifi for speed dependant devices
Other than that your speed is the fastest possible and hasn't dropped in 300 hours
Avatar for Jbvhmcg
@Jbvhmcg
Avatar for Jbvhmcg
Worked a treat so far thank you!
