Discussion topic: Intermittent/Slow Access to Skyhub
This message was authored by Fatmanp89 This message was authored by: Fatmanp89
I have noticed that over the last few days it takes forever to access the skyhub. In some casesd it just comes up and says the "Skyhub is busy, Please try again later". This started around Monday this week. When I have been able to access the router stats I can see that the hub has been connected since about May 7th without any disconnections.
I dont want to reboot the hub in case I ended up in the line training mode and the speed drops but is this a common issue? Please note that it is the same trying to access wired via PC or wireless via my phone.
Re: Intermittent/Slow Access to Skyhub
@Fatmanp89
Can you post your hub stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Fatmanp89
I will try but it keeps saying the hub is busy its pot luck if it will load.
Also whenever I run this
Broadband check | Sky.com
It says the hub is not responding to checks.
The internet is working fine
@Fatmanp89
Try resetting it via the reset button at the back . It is only regular resets that may trigger dlm
Fatmanp89
Thanks. That seemed to fix it. I would have just waited for the reboot to occur naturally but the wifi performance had massively deteriorated. All good now.
