Discussion topic: Installation of DSL-AX82U for sky fibre ireland
Re: Installation of DSL-AX82U for sky fibre ireland
@BSIrl
You are still in dsl mode.  Can you click that drop down and see if it allows you to set wireless router mode.
@BSIrl
Also even if you have the correct vlan of 10 you need to enable it in the field above
Avatar for BSIrl
This message was authored by: BSIrl
Hey, I thought i had set it to wireless router mode based on the screenshot, and also earlier i had tried setting it to WAN mode as you see in the other screenshots
Screenshot 2024-04-02 at 19.09.32.pngScreenshot 2024-04-02 at 19.09.08.pngScreenshot 2024-04-02 at 19.09.18.png
Avatar for BSIrl
just to clarify ive also enabled the setting you suggested there for VLAN, hopefully we are getting closer to solving this issue
Avatar for BSIrl
Hello everyone, the issue is solved, thank you for all your patience
This message was authored by: suchfunkymonkey
I'm having the same issue as you.  What did you do to resolve it?
I managed to figure it out.  Sky technical support were no help at all.  They said they didnt have any details.
Posting the details here for anyone finding this page from a search engine.  People saying they resolved their issues on threads without saying what the fix was is just frustrating.  So is trying to piece answers back together from multiple posts/threads.
The below details are for Sky Fibre (FTTP) using a 3rd party router (ASUS DSL-AX82U).
They may not be optimal, but they work and im getting download speeds of 937Mbps.
If you have just got the fibre installed, you may need to power it off and leave it 30 minutes.  I waited overnight.
DSL-AX82U firmware version: 3.0.0.4.388_23756
Advanced Settings -> WAN -> Internet Connection
WAN Type -> WAN
PVC -> Internet PVC
WAN -> PPPoE
Enable WAN -> Yes
Enable NAT -> Yes
Enable UPnP -> Yes
802.1Q
Enable -> Yes
VLAN ID -> 10
802.1P -> 0
WAN IP Setting
Get the WAN IP automatically -> Yes
WAN DNS Setting
Connect to DNS Server automatically -> Yes
DNS Privacy Protocal -> None
Account Settings
Username -> anything@skydsl
Password -> anything
PPP Authentication -> Auto
Disconnect after time of inactivity (in seconds) -> 0
MTU -> 1492
MRU -> 1492
Service Name -> Leave Blank
Access Concentrator Name -> Leave Blank
Host-Uniq -> Leave Blank
Internet Detection -> PPP Echo
PPP Echo Interval -> 6
PPP Echo Max Failures -> 10
Addition pppd options -> Leave Blank
Special Requirement from ISP
Enable VPN + DHCP Connection -> No
Host Name -> Leave Blank
MAC Address -> Leave Blank
Extend the TTL value -> No
Spook LAN TTL value -> No
MTU -> 1496
