Discussion topic: Installation due tomorrow but hub has not been delivered
This message was authored by: Tania19
Im supposed to have had my hub delivered on monday and kept waiting for it but it hasnt been delivered and my instalation is tomorrow. What shall I do?
Re: Installation due tomorrow but hub has not been delivered
@Tania19 the hubs are dispateched by post to arrive a couple of days before the activation so it should be delivered today or indeed tomorrow.
If it doesnt then it wont stop the activation which does not require a router to be connected but of course you wont be able to use the service. Call Sky after the line goes live and they should send a replacement out. Until thst point they can do nothing.
Avatar for Tania19
Thanks so much Christee , I thought I would need my hub for installation. That reassures me a lot
Avatar for Tania19
Will sky expect me to start paying for broadband even though the hub has not been delivered?
@Tania19
If they do charge you from tomorrow then once the hub has arrived contact Sky who will hopefully place a (small) credit on your Sky account.
