Discussion topic: Im wanting to remive a device from my wifi iv changed password but its still connected
Message posted on 24 Jul 2024 10:00 PM
I'm trying to remove a device from my wifi iv changed password but it's still connected
Message posted on 25 Jul 2024 06:12 AM
Re: Im wanting to remive a device from my wifi iv changed password but its still connected
@Gen3 that sounds very odd as when you applied the change to the hub it would have restarted in the process disconnected all of the WiFi devices which would have needed to be re-connected using the new password or using the WPS system which requires physical access to the hub to start the process. The only devices which would reconnect automatically are those connected by ethernet.
Do you have third party wiifi boosters? Are you by an chance misidentifying a device you havecreconnected yourself as the details on the hub's device list can be misleading including device being listed as unknown which only means tge device is not returning an identity not thst it isnt ine of your own devices.
