4
This discussion topic has been answered Discussion topic: I want full fibre@ £29 / month
This message was authored by: MikeWright1
How do we get full fibre connected to our property.
Re: I want full fibre@ £29 / month
@MikeWright1 Sky do not lay fibre themselves they currently only use the Openreach network.  Therefore you can only buy Sky's full fibre service if your road has  to Openreach fibre available.
You can check here for what is known about what Openreach fibre roll out see https://www.openreach.com/fibre-checker
This message was authored by: daveNOS
@MikeWright1 If Full fibre is available at your address then place an order with Sky and they will provision the install and activation.
You can check here https://www.broadbandchecker.btwholesale.com/#/ADSL you may need to use the address checker.
@MikeWright1
The current target for Openreach to complete the 'commercially viable' part of the  national FTTP rollout (putting a full fibre connection within reach of somewhere between 80 and 90 percent of UK addresses at no additional cost to the occupants) is by the end of December 2026.
Avatar for MikeWright1
Thank you all for your comments.
