7
This discussion topic has been answered Discussion topic: I’ve tried all day to get my Sky network setup to connect to sky box
This message was authored by: CT07
Every time I try and do this it tells me to press the WPS button on my router and guess what? There isn't one🤷🏻‍♀️ I've pressed the same button on the sky Q box to no avail. I can't download any apps and I've tried unplugging absolutely everything and that also doesn't work. Any ideas or suggestions?
Avatar for CT07
This message was authored by: CT07 Answer
Re: I’ve tried all day to get my Sky network setup to connect to sky box
Thanks guys! I've just done a quick sprint between both buttons and it's finally worked! Many thanks for your help and advice 🤗
@CT07 wrote:
Every time I try and do this it tells me to press the WPS button on my router and guess what? There isn't one🤷🏻‍♀️ lugging absolutely everything and that also doesn't work. Any ideas or suggestions?
There is, depending on the hub type if it's not on the front it's on the right hand side.
Avatar for CT07
Thanks but I've tried that button on the sky Q box as stated above and have had no joy.
Avatar for CT07
Should explain I have pressed the WPS button on the router and waited until everything goes green and it says "unsuccessful connection please try again, or you may need to connect a Sky Q Booster" how do I request one of those?
@CT07  You would need to call Sky and you would also need broadband boost.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
@CT07
Just to be clear, have you pressed the WPS button on both of the two devices (the Hub and the Q television box) in quick succession?  A button press on each individually doesn't do anything: it's doing both which tells them to set up a link.
Sky will loan booster hardware to resolve Q issues, but you'd need to call them.
Avatar for CT07
I can't do that easily because the router is in one room and the box in another.
Avatar for CT07
