Discussion topic: I received my sky booster yesterday and wont connect
Message posted on 27 Jun 2024 06:45 PM
I have tried resetting it ans moving it around
Message posted on 28 Jun 2024 07:34 AM
Re: I received my sky booster yesterday and wont connect
@Lisankeith try connecting the booster in the same room as the hub if it wont connect there usingbthe WPS buttons as the instructions tell you the unit is likely to be faulty. If it connects tgere move to a position no more than half way to where you need the boost and see if it reconnects automatically if it doesnt its not getting sufficent signal to work,
Message posted on 28 Jun 2024 07:36 AM
Thankyou. We tried all that and still no light in the middle so most probably faulty I phone them up later
