Discussion topic: I need a replacement cable, (round, blue end connection) to fit into back of sky hub box
This message was authored by: ELJAY9873
I need a replacement sky WiFi cable (round, blue end connection) that fits it back of sky hub box.
No more information to give. That's what I need,  OR TO SPEAK TO A REAL PERSON.
just rang your number ,got automated response, no good, did not include my option and was finally cut off when they sent a link. Useless customer service
This message was authored by: Jporch316
Re: I need a replacement cable, (round, blue end connection) to fit into back of sky hub box
we are all customers on here ....
If you ignore the part of the call that asks for your mobile number (don't enter it ) to send a link you can normally get through to customer services
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Um, WiFi doesn't use cables?
Possibly an ethernet cable, I guess.
@ELJAY9873
Ah, the power lead for an ER115 Sky Q Hub / Sky Broadband Hub?
