Discussion topic: I’m unable to insert the grey cable into phone socket
This message was authored by: Skyplus-11
Message posted on 16 May 2024 10:02 AM
It seems phone socket has smaller chip than the cable. Can we break off the side clip and insert it again?
Find out more
Message posted on 16 May 2024 11:15 AM - last edited: 16 May 2024 11:18 AM
Re: I’m unable to insert the grey cable into phone socket
RJ11 won't fit a 'BT jack' (BS6312 431A) socket, if that's what you are trying to do. If your wallbox faceplate only has BT jack then you'll need to obtain a microfilter.
