Discussion topic: I’m getting no WiFi signal it’s all plugged in and non signal
Message posted on 28 Aug 2024 08:39 AM
I'm not getting any signal for my WiFi
Message posted on 28 Aug 2024 08:48 AM
Re: I’m getting no WiFi signal it’s all plugged in and non signal
@timbo00 black or white route from Sky?
Message posted on 28 Aug 2024 08:58 AM
White
Message posted on 28 Aug 2024 09:05 AM
@timbo00 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 30 Aug 2024 12:56 AM
Have a issue with broadband
Message posted on 30 Aug 2024 09:23 AM
@timbo00 Did you follow the directions that where posted above to see if this could find the fault?
Message posted on 30 Aug 2024 11:27 AM
It says I have a issue
Message posted on 30 Aug 2024 11:31 AM
@timbo00 Did you follow through on what the issue is and what solutions it was giving you for fixing it or did it just go green as fixed?
