Discussion topic: I have sky stream and my broadband keeps going down.?
Message posted on 13 Jun 2024 02:09 PM
My hub has four lights and light number 2 and 4 change from Green to orange, everything then goes off (broadband WiFi, sky stream TV). After a few mins they turn back green and all comes back on but this now happens anything between 5 and 10 times per day.
Has anyone else had this issue?
thanks
Message posted on 13 Jun 2024 02:14 PM
Re: I have sky stream and my broadband keeps going down.?
Can you post your router statistics
Message posted on 13 Jun 2024 02:35 PM
Having the same issue for weeks now..north wales
Message posted on 13 Jun 2024 04:44 PM
@GaryJC1 & @Francamm Can you follow the directions below the next time your internet drops.
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
