Discussion topic: I have ran a test on my laptop and i am only getting 10mbps
This message was authored by: JayS84
Upload
I have also had the internet drop off at the router 3 times i can recall in the last week, i never had this issue with the old internet and my sons gaming keeps lagging
Re: I have ran a test on my laptop and i am only getting 10mbps
@JayS84 when you run a speedtest on a device the result is the slowest part of the connection which unless you sre using Ethernet cables is the WiFi in your home. WiFi is affected by the layout and cobstruction of your home together with the level of interference.  That wouldcalso explain the lag your son gets when gaming.
You can try re-starting your hub as that will make it find yge least congested channel to use but that can often beca temporary sokution at best. Given everyonecwants fast WiFi and there are a limited number of WiFi channels this issue is getting worse. The best solution is getting a better WiFi set upmin your home Skybwill sell you their WiFi Max bundle see https://www.sky.com/help/articles/sky-wifi-max or you can buy your own kit.
