Discussion topic: I have plugged box in with wires and says can’t connect
This message was authored by: Libby16
I need help with getting the internet to work
This message was authored by: Hopeful1
Re: I have plugged box in with wires and says can’t connect
@Libby16
You will need to detail a bit more.  What router is it, it will something starting with SR-something.
then, detail what cable you have put where.
good luck
Avatar for Libby16
It's the new black box and I have plugged it into the phone but I have done everything sky showed me to do
