Discussion topic: I have no connection to the internet
This message was authored by: Laura417
I have run the various tests, there is a red lid light at the wall yet the app says everything is working
Re: I have no connection to the internet
@Laura417
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
