Discussion topic: I have no broadband since saturday. Orange voice light no internet light.
This message was authored by: Innersmile
When I am asked to do connection tests sky says it doesn't recognise my email. I have e done all the remove cables press reset but nothing changes. Any ideas please welcome
Re: I have no broadband since saturday. Orange voice light no internet light.
@Innersmile if your broadband isnt working call Sky. Sounds like you are not using the correct Sky id for the Brosdband account when trying to use the online system. Each id is linked tonan email address and these must mstch the one used to set up,tge account. If you are certain you arecraise the issue with thecagent when reporting the fault as they can get thst fixed as well.
Avatar for Innersmile
Thank i will. I have been using this account for some .months so will raise with sky
