Discussion topic: I have no Wifi connection
Message posted on 22 Feb 2025 02:30 PM
Message posted on 22 Feb 2025 02:43 PM
Re: I have no Wifi connection
@M-Taylor
Not sure what you mean by all the tests so if you haven’t done it already use the below link to check to see if there are any problems or outages nearby
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
