Discussion topic: I have just received my sky hub but I am unable to get connected to WiFi, please help me connect
This message was authored by: SKY5ZQSG
I have just received my sky hub and I am failing to get connected. Not sure what I am doing wrong here. The hub came with 2 cables which are the black power cable and one with yellow ends. It seems there is something missing as I cannot get the WiFi connection
Re: I have just received my sky hub but I am unable to get connected to WiFi, please help me connect
@SKY5ZQSG
A cable with yellow ends is ethernet, and that means it's intended for connection to an ONT for service over FTTP ('full fibre')
If your property doesn't currently have FTTP installed (a Hub is sent out in advance) then the new optical cable and ONT will be installed on the activation date.
@SKY5ZQSG
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
