Discussion topic: I have full fibre broadband and this morning can or connect. All lights are green on open reach bo
This message was authored by: HP7786
I need help I have no broadband connection
Re: I have full fibre broadband and this morning can or connect. All lights are green on open reach
@HP7786 check the lights on your Sky hub if the connection is down the internet light will be amber as will the voice light. In thst case run the connection test in the My Skky app overca mobile connection - dont get confused by the result from the last test which shows when you open the page click to run the test again. Thst will tell you if there is a known fault if there isnt call Sky to report the pproblem
If the hub lights are all green then the issue is in your home check that your devices are connecting properly  rdbooting devices snd hubs can often restore connection.
