Discussion topic: I have a sky max hub and I can’t connect security cameras
Message posted on 03 Nov 2024 11:55 AM
I have just had a sky max box installed, but now I can't connect my security cameras as they are 2.4ghz. Please can anyone help as I am not tech savvy thank you.
Message posted on 03 Nov 2024 12:06 PM
Re: I have a sky max hub and I can’t connect security cameras
You may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub administration settings in the My Sky app. You can also use those settings to temporarily disable the 5Ghz WiFi band, which may help with getting such devices to connect.
Message posted on 03 Nov 2024 12:10 PM
Thanks for replying as I said I am worried that if I mess with anything it will muck the set up and things may not work.
Message posted on 19 Nov 2024 01:02 PM
Could you provide how you did get them working as I have the same issue
thanks
