Discussion topic: I had sky fibre installed by sky, but the installer damaged my property, 4 months later,
This message was authored by: Tfont
When they installed the fibre, the engineer from sky damaged the render on the front of my house, 4 months later and numerous calls to sky, and sky to others the situation is the same, I still have my damage
Re: I had sky fibre installed by sky, but the installer damaged my property, 4 months later,
@Tfont  I'm not sure what you want fellow customers to do or advise as Sky are already aware.
Have you chased them up?  Raised a complaint?  https://www.sky.com/help/articles/sky-customer-complaints-code-of-practice/
Avatar for Tfont
Level 0 icon
Done everything, like I said it's now 4 month, I want to complain to someone higher than sky, there a world wide company, I'm a little person
This message was authored by: Wayne2908
There used to be a company based in Hertfordshire that carried out all sky repairs. They had guys all over uk.
I worked for them, not sky.
They would get complaint and send it out to whichever area it was.
I know the main guy Andy retired to Spain.
Dunno if it's still going, I think Sky took the repairs on in-house.
The company was called N A Carpentry
@Tfont if you haven't already done so make a formal complaint see How to make a Sky complaint | Sky Help | Sky.com
The issue is likely to be caused by the fact the installation of new fibre lines is Openreach's respomsibility not Sky's but the complaint system requires an answer within 8 weeks when you can take the issue to independent arbitration.its worth getting an estimate for the repair.
