Discussion topic: I got new sky max but it keeps dropping. Worse connection than with sky w
This message was authored by: Stephanie361
I got the new Sky max box to help with signal throughout the house but it's awful. It keeps dropping out - so far today it's been 4 times and during a work call.
I need help!
Re: I got new sky max but it keeps dropping. Worse connection than with sky w
@Stephanie361 like all WiFi routers the new WiFi Mx hub needs to be out in the open and on a surface above obstructions like radiators etc. If your's is in the best pisition you need to talk to Sky as you may need extender pods which can come as part of WiFi Max add-on package.
The new hubs are faster than the older black type but do not have a greater range on their own and signal strength drops the further you are away from the unit and the number of solid objects it has to pass through.
