Discussion topic: I cant get WiFi in my bedroom
This message was authored by: Thirtysixgees
Message posted on 15 Dec 2025 10:44 PM
The WiFi is good throughout the house except the bedroom which TBF is the furthest point from the router. I have checked my devices on the test and it confirms it
Find out more
Message posted on 15 Dec 2025 10:49 PM
Re: I cant get WiFi in my bedroom
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
